Author Topic: Automatic adjust of operation of realization  (Read 3064 times)
dagraf
« on: November 25, 2008, 06:36:04 pm »
I'd like to write an add-in which handles adjustment of operation names of realization. If operations OpA and OpB from ClassA are realized by ClassB, ClassB has the operations OpA and OpB. When I now rename OpA to OperationA from ClassA my add-in has to rename this function in ClassB.
Now my problem is that each function has its own GUID and there is no relation between the functions.  :-/ Has anyone an idea how to handle this?
Thanks for your answers!  :)
Frank Horn
Re: Automatic adjust of operation of realization
« Reply #1 on: November 25, 2008, 07:40:25 pm »
There's no relation indeed. That's why I think EA's inbuilt function to add realizing or overriding operations is worthless.
You can roll your own though, and don't even need an AddIn. In the Settings-UML dialog, tab "Tagged Value Types", you can define a type, e.g. "RealizationRef", and enter
Type=RefGUID;
Values=Operation;
in the detail field.
Then you can give each realizing operation a tagged value of type RealizationRef which points to the operation it realizes.
Of course you can write an AddIn to replace the "Element-Advanced-Overrides & Implementations" menu, but then you'll need to roll you own dialog with operation selection as well.
