Author Topic: Element\Diagram - rendering via docu generator  (Read 2821 times)
Martinigue
  • BlackBerry is a lifestyle
« on: September 07, 2010, 08:37:40 pm »
Hi all,
assume a ( UC) package with 10 UC elements. Two of them have a diagram attached/embedded ( unfortunately I do not know whether the diagrams were all added via the 'Add/Add Diagram' option). Now, when I run F8, only one of the diagrams gets rendered in the output file, the other one never does. I played with the other UC elements and did the 'Add/Add Diagram', yet none of these got rendered in the output, but when I Add/Add Diagram'd another diagram to the only UC element that actually renders the diagram, the other got rendered too. So basically I have one UC element which renders its diagrams in the output perfectly, and nine UC elements that never do. What is it that is different between these??? I looked everywhere ...
Martinigue
Re: Element\Diagram - rendering via docu generator
« Reply #1 on: September 08, 2010, 04:11:55 pm »
Ok, this one is solved now ...:-)
Hi all,
« Reply #2 on: September 08, 2010, 04:40:06 pm »
Maybe you could tell us how you solved it?
Might be interesting for other who have the same problem and find this topic.
