Author Topic: Deployment Diagram - Re-use a server gold image  (Read 3051 times)
EANewbie
« on: September 28, 2010, 07:25:40 am »
EA Experts
I am constructing a Deployment Diagram using EA.  I have created a server XYZ with a specific set of attributes, including RAM, OS, etc.  These attributes are visble when constructing an instance of this in EA.  Next, I have created a WebLogic Server artifact that represents my WebLogic Server container and includes attributes, such as Version.  I have created a Component that represent an application EAR (ABC) that I deploy into that WebLogic Server component.
I would like to create an instance of the server XYZ, the WebLogic container, and the Component and call this combination my App Server Gold Image.  I would then like to use that gold image in various flavors of my deployment diagrams.  I would like to be able to set it up once where the application EAR is contained in the WLS instance, which is contained in the server instance -- with all the attributes of each displayed.  I have constructed the gold image, have all attributes of each element displayed, and everything sized nicely.
So, here is the problem.  When I try to use this gold image on another diagram or in another package by create a direct link to this Gold Image or copy-and-pasting into package, the Web Logic container and the Application EAR are not visible in the diagram.  Instead, I have to re-drag the sub-items (WebLogic and App EAR) to the diagram.  If I have a single deployment diagram that contains 50 instances of this gold image, I have to do this 50 times.  What's worse?  If I change one of the attributes, it causes a resize to be necessary -- you guessed it -- on each of those 50 instances.
How can this be avoided so that I can get real re-use out of the gold image?
Your help is much appreciated.
Re: Deployment Diagram - Re-use a server gold imag
« Reply #1 on: September 28, 2010, 09:00:52 am »
Have a look at UML Patterns in the help file - they may be of some use.
EANewbie
« Reply #2 on: September 28, 2010, 11:41:42 pm »
Thanks for the feedback.  This has been helpful in progressing my understanding of EA.
UML Patterns looked promising initially, but here is the problem I am encountering when attempting to leverage them in this scenario.
I have created my pattern two ways.
First, I created it based on instances of elements I had defined.  When creating the UML Pattern with instances, the "Preview" of the pattern looks perfect, but when I add the pattern to a diagram, it loses the names of the objects (server node, artifact, and component) and it loses the attributes of those objects.  Again, the "Preview" shows the names and attributes perfectly -- just as I would like to see them.
Second, I created it using Direct Links from each of the objects.  Specifically, I constructed a diagram using direct links and then saved that as a UML Pattern.  When dragging that UML Pattern onto a diagram, it looks perfect -- names and attributes in-tact.  However, if I then alter the pattern, the changes in the pattern do not get applied to the places where I used the pattern.
The second attempt is a solid step forward, but without being able to alter the pattern and see those changes applied (or at least asked if I want to apply them), I am back at square one.
Is there a way around this?
If not, I guess I just need my pattern to be in a final state so that revisions are no longer an issue.
