Author Topic: HELP w/Use Case Diagram & Requirements  (Read 4011 times)
Bonita
« on: October 01, 2010, 04:07:23 am »
Hello - I'm a new EA user and am struggling setting up a Use Case.  I have setup my Actors, Interfaces and Primary Use Cases, but somehow the relationships are not showing up on the diagram. Meaning all actors associated with a particular task are not on the diaghram.
In addition, I setup a System Admin Primary Use Case and when I view the diagram there are only 2 out of 7 main actors shown, but the Actors are present in the Use Case Package.
Finally, how do I save the Requirements description once entered. Within the Requirements tab, I type in my description, click Apply, Okay, and then click Save the Current Diagram Icon, but it's not saving when I go back and check.
Any advise I'd greatly appreciate.
Re: HELP w/Use Case Diagram & Requirements
« Reply #1 on: October 01, 2010, 03:26:05 pm »
Bonita,
What do you mean by "actors association with a particular task"?
Are you expecting that EA puts the actors on a diagram automatically? AFAIK you have to put the actors you want to show on the diagram yourself.
Everything in EA is saved immediately when you press save/ok/apply button. The "Save Current Diagram" button does exactly what it says. It saves the (layout of) the diagram, nothing else.
Kris Nunes
« Reply #2 on: October 01, 2010, 04:23:19 pm »
Bonita,
The EAExample.eap should have an example to get you started.
If you need more details on requirement management there are some demos and manuals on the same.
http://www.sparxsystems.com/downloads/whitepapers/Requirements_Management_in_Enterprise_Architect.pdf
http://www.sparxsystems.com/resources/demos/index.html
Kind regards,
Kris Nunes
Bonita
« Reply #3 on: October 01, 2010, 11:16:08 pm »
Thanks so much Geert and Kris - both your suggestions helped me out!
I'll be an EA pro, such as yourselves, in no time [smiley=2vrolijk_08.gif]
sargasso
« Reply #4 on: October 06, 2010, 10:56:27 pm »
Insincerely, the bind moggles. ::)
but, best of luck! :D
« Last Edit: October 06, 2010, 10:59:08 pm by sargasso »
