Author Topic: Project Integrity Check and Version Control  (Read 3505 times)
ChrisBD
« on: April 27, 2010, 06:13:50 pm »
Just a quick question.
It has been stated by some users that when running EA's Project Integrity Check it is best to select for it to recover/fix errors automatically.
How does this work when a project is under version control? Will it check out packages before it fixes them? What about items that are already checked-out?
I suppose that I could duplicate the model repository that I have and the ClearCase VOBs as well in order to check this, but it would take at least a day's work. So I'm hoping that someone here can answer directly from experience.
Damir
Re: Project Integrity Check and Version Control
« Reply #1 on: October 13, 2010, 07:51:18 pm »
I'm having the same problem-question
can someone explain how this is processed?
thanks!
« Reply #2 on: October 13, 2010, 09:51:04 pm »
I think most of the things that are fixed aren't actually exported to xmi, and as such do not change anything on your version control, but you better test this to be sure.
