Author Topic: Prevent generation of "finalize()" methods?  (Read 4316 times)
pstein
« on: November 03, 2010, 06:51:33 pm »
Assume I have a data class diagram and generate appropriate Java Classes from it.
Unfortunately all java classes contain "finalize()" methods.
How can I tell EA to NOT generate those methods?
Peter
Re: Prevent generation of "finalize()" methods?
« Reply #1 on: November 03, 2010, 07:21:10 pm »
I think Tools/Options/Source Code Engineering/Object Lifetimes and then deselect Generate Destructor.
ajaimes
    • Andres Jaimes
« Reply #2 on: August 03, 2018, 01:06:17 am »
Yes. There are two ways to do it:
Option 1: Disabling constructor and destructor generation class by class. Right click on your class > Code Engineering > Generate Code > Advanced > Object Lifetimes. Uncheck Generate Constructor and Generate Destructor.
Option 2: Modifying the Java code generation templates. Go to the Package menu > Code Engineering > Code Generation Templates... > Language Java > Class Body and remove the following two sections:
$ops=""
%if genOptGenConstructor == "T" and classHasConstructor != "T"%
$ops+="\tpublic "+%className%+"(){\n\n\t}"
%endIf%
and
%if genOptGenDestructor == "T" and classHasDestructor != "T"%
$ops+="\n\n\tpublic void finalize() throws Throwable {\n"
$ops+=%classHasParent=="T" ? "\t\tsuper.finalize();" : ""% + "\n\t}"
%endIf%
hoylet
« Reply #3 on: September 23, 2026, 07:51:43 pm »
In version 17 to suppress the generation of destructors or finalize methods :-
From the ribbon Settings.Model.Options select Source Code Eng. Object Lifetimes uncheck Generate Destructor
