Author Topic: How to Find link b/w block & its instances?  (Read 6456 times)
hshahid
« on: November 08, 2010, 11:52:23 pm »
I am using EA. 8.0, its API and C#. I have created a SysML block "Car" in a diagram and then created its instance in the same diagram "BlackCar:Car".
Now what happens is when I create a new instance of a block, EA creates a new property in in the repository and name it "BlackCar", but using API, I am not able to get relation b/w the block and its instances. i.e. I am able to get "BlackCar" as a property in my XML but I am not sure which attribute of API "Element" will contain the information about showing any relationship b/w the instance "BlackCar" and its type which should be "Car".
Can any one guide me, how I can reterive this information using API. I have tried different properties, e.g, Element.MetaType, Element.Type etc etc... but was not able to guess the property which will actually tell information required.
Thanks & Regards,
Hamid
Re: How to Find link b/w block & its instances?
« Reply #1 on: November 08, 2010, 11:57:12 pm »
Hamid,
Have you tried Element.ClassifierID ?
hshahid
« Reply #2 on: November 09, 2010, 12:32:10 am »
Yes Greet,
I have tried all these properties like ClassfierID, ClassifierID, ClassifierName, ClassifierType but they are not providing the information needed.  :(
« Reply #3 on: November 09, 2010, 12:45:15 am »
Hamid,
What is in ClassifierID then?
hshahid
« Reply #4 on: November 09, 2010, 12:51:24 am »
Greet its "0" in everycase.
« Reply #5 on: November 09, 2010, 12:55:24 am »
Then I have no idea. I guessed the Sysml instance would be like a UML object, but apparently that is not the case.
hshahid
« Reply #6 on: November 09, 2010, 01:28:45 am »
Thanks Greet.
Any suggestions anyone...?
hshahid
« Reply #7 on: November 10, 2010, 12:15:26 am »
Guys any ideas...
« Reply #8 on: November 10, 2010, 08:27:44 am »
If Geert is unable to help, your best bet would be to put in a support request.
« Last Edit: November 10, 2010, 08:28:01 am by skiwi »
« Reply #9 on: November 10, 2010, 08:42:24 am »
I think you'll the guid of the type in MiscData(0) (or PDATA1).
hshahid
« Reply #10 on: November 10, 2010, 11:44:08 pm »
Hi Skiwi - Thanks.
Hi Simon,
I guess it is not the ID because, I tried myElement.get_MiscData(0), but it returns a strange kind of value ="{057293CA-F6F7-45b3-832D-F264AA990DCE}".
Please let me know, if Element ID of the type can be extracted from this value? We can see the Type of the sysml block object in E.A, so there must be a way by which E.A maintains the association when its running.
Please let me know, your views about it.
Thanks.
« Reply #11 on: November 11, 2010, 08:22:17 am »
It's the guid.
Try Repository.GetElementByGUID.
« Last Edit: November 11, 2010, 08:22:30 am by simonm »
hshahid
« Reply #12 on: November 13, 2010, 01:01:43 am »
Thanks Simon, it worked :)
Following Code is to help someone who is facing same problem;
classElement = (EA.Element)m_Repository.GetElementByGuid(tempElement.get_MiscData(0));
if (classElement != null)
      className = classElement.Name;
      cassID = classElement.ElementID;
