Author Topic: Relationship Matrix and RTF  (Read 6529 times)
Maggie
« on: October 27, 2010, 08:22:43 pm »
Hello everyone
I realize (after searching the forum) that I cannot include a Relationship Matrix profile in an RTF report.
Has anyone found a suitable workaround for this?
TIA
Maggie
Fred Bevan
Re: Relationship Matrix and RTF
« Reply #1 on: October 28, 2010, 12:09:13 am »
I haven't found a slick automated way to do this.
The best approach that I have found is to export the matrix to .CSV, do some formating in EXCEL and then paste it into WORD as a table.
alesliehughes
« Reply #2 on: October 28, 2010, 08:51:48 am »
This feature has been implemented and should available in EA 8.1 (once it's release).
Maggie
« Reply #3 on: October 28, 2010, 06:21:41 pm »
Thanks for the update
When can we expect EA 8.1?
Maggie
philchudley
« Reply #4 on: October 29, 2010, 02:17:42 am »
If you are using EA version 8.0, you can export the matrix as a graphic, then insert this on a linked document for an element (I use a package)
Then the linked document can be output easily in the RTF generator. This is just an interim stop gap, and of course the graphic would need to be re-inserted every time the matrix changed.
Good news about the implementation in EA v 8.1
Cheers
Phil
Models are great!
Graham_Moir
« Reply #5 on: November 01, 2010, 09:30:15 pm »
Well this is great news.  I wonder if 8.1 will appear before Christmas or sometime in 2011 ?
Rick Sjogren
  • Sing Ho! For the life of a Bear!.
« Reply #6 on: November 16, 2010, 11:15:28 am »
Do you know if this new feature means that I will be able to embed diagrams in a linked document directly without first having to save them to a file?
I sure hope so. Note, if such a feature has already been implemented, can you let me know, please?
Rick
Quidquid latine dictum sit, altum sonatur.
'Whatever is said in Latin sounds profound.'
alesliehughes
« Reply #7 on: November 16, 2010, 12:52:30 pm »
If want the image a Linked Document, then you will have to save it to file first.  If you want it in a generated RTF report, you just need to enabled the Matrix section.
Alistair
