Author Topic: Plugin version dependency  (Read 3393 times)
DoB
« on: December 11, 2008, 12:07:29 am »
I have developed an EA plugin and distributed it to users along with the EA interop dll. The plugin crashes ocassionally for users that use different versions of EA than I use.
The problem is that I cannot effectively force all the supposed users to use my version od EA.
I guess that the problem might be solved if I did not didtribute the interop dll and use the actual dll on the user's machine instead. But the actual dll should be in the Global Assembly Cache. I browsed my GAC and could not find the EA interop dll there.
The questions are:
- does EA register its Interop in GAC on install?
- if not... could it? ;-)
- maybe there is another way of solving the addressed issue?
DoB
