Author Topic: Attach Note to Sequence Diagrams  (Read 7855 times)
Maanu
« on: November 25, 2010, 03:28:21 pm »
I would like attach notes to vertical lines (lifelines corresponding to classes) in sequence diagrams. How can we do that? I am using EA 7.1
Thanks!
Re: Attach Note to Sequence Diagrams
« Reply #1 on: November 25, 2010, 05:21:29 pm »
Maanu,
In 8.0 you can simply use the note link to connect notes with lifelines. Is this not working in 7.1?
Maanu
« Reply #2 on: November 25, 2010, 06:34:33 pm »
I do not understand your answer. Can you give the steps to follow to link a note to a lifeline?
« Reply #3 on: November 25, 2010, 06:55:36 pm »
- put a lifeline and a note on the diagram
- click on the "note link" icon in your toolbar
- drag from the note to the lifeline.
AlanT
« Reply #4 on: November 29, 2010, 08:18:57 am »
BTW, why can`t a user connect a note to a message?
                   Alan
« Reply #5 on: November 29, 2010, 02:36:47 pm »
yes, sure.
AlanT
« Reply #6 on: November 29, 2010, 09:32:08 pm »
No, I mean EA does not allow a user to connect a note to a message.  It should.
                  Alan
« Reply #7 on: November 29, 2010, 11:49:52 pm »
Alan,
I misunderstood, but yes you can connect notes to messages.
Right click on Note|Advanced|set attached links.
AlanT
« Reply #8 on: November 30, 2010, 01:28:35 pm »
Geert,
     Thanks!   8-)
   This does seem stange that you cannot simply drag an arrow over to the message, like you can to other objects.
                                     Alan
« Reply #9 on: November 30, 2010, 05:18:46 pm »
Strange? No, EAUI Yes  :P
« Reply #10 on: December 01, 2010, 08:38:59 am »
Works quite nicely in the build of EA I'm using.  Of course it's not ready for release yet.  But it's coming.
« Reply #11 on: December 01, 2010, 03:19:14 pm »
Simon, enough already, stop teasing us ;)
It 8.1 still planned for this year, or has the release date slipped into 2011 already?
« Last Edit: December 01, 2010, 03:20:43 pm by Geert.Bellekens »
yonatan.lehman
« Reply #12 on: February 01, 2022, 04:47:24 am »
12 years later and I still only get a dialog with a list of messages in an order that does not correspond to their order in sequence and I have to guess which message I'm going to connect to (two messages that only differ by the parameter which is not shown)
Yes it does draw it when I click the select box - but ......
am I missing something?
yonatan.lehman
« Reply #13 on: February 01, 2022, 05:00:20 am »
Found it (trial and error)
Drag an arrow from the comment to the message and shift click !
To delete it you still need to go via the Advanced Set attached links menu.
