Author Topic: RTF-Template Editor: Scenario Problemens  (Read 3526 times)
nclaasen
« on: November 30, 2010, 09:17:37 pm »
Hey People,
I have a little problem with the export of the scenarios in use-case elements. This is my current scenario section:
scenario >
{ElemScenario.Type}
{ElemScenario.Scenario}
structured scenarios >
   {Scenario_Structured.Step}.  {Scenario_Structured.Action}
< structured scenarios
< scenario
1st Problem: Order of the scenarios types:
Currently the scenario types are generated in the following order:
Alternate Paths
Exception Paths
Basic Paths
Is there any way to change it into the following order?
Basic Paths
Alternate Paths
Exception Paths
2nd Problem: Show Entry an Join Points of alternate an exception paths
Is there any way to display the entry point in front of the {ElemScenario.Scenario} entry?
And is it possible to automatically show the join point as the last step?
Greetings
Nils
Fred Bevan
Re: RTF-Template Editor: Scenario Problemens
« Reply #1 on: December 01, 2010, 12:16:28 am »
1st problem: Order of Scenario Types
You can specify the order of scenarios reported in RTF reports by following these steps:
•      Open the Properties dialog for the Use Case
•      Select the Scenarios tab and the Description sub-tab
•      Use the Up/Down arrows at the bottom of the dialog to order the scenarios
•      Sorry, no idea but I would also like to know if there is a way to do this.
nclaasen
« Reply #2 on: December 01, 2010, 11:54:28 pm »
Thank you for your reply. Problem 1 is solved!
alesliehughes
« Reply #3 on: December 02, 2010, 09:10:12 am »
The Join field will be found in a future build of EA.
Alistair
