Author Topic: Eclipse - Workspace Unavailable  (Read 3106 times)
Miguel Gonzalez
« on: December 03, 2010, 10:48:37 am »
I have changed EA Options so my Java editor is eclipse.
When I hit F12 for "View Source Code", Eclipse tries to open but I get the pop-up error message that says... "Workspace in use or cannot be created, choose a different one."
Choosing a different one does not work, it opens Eclipse with the choosen workspace but the code does not appear.
Any ideas on how to make this work?
Thank you.
Miguel Gonzalez
Re: Eclipse - Workspace Unavailable
« Reply #1 on: December 03, 2010, 11:19:37 am »
I have found out that this is happening because the way Eclipse is installed by default.
First, I was getting that error message because I had another instance of Eclipse running. Eclipse installs in a way that it allows running multiple instances. When hitting F12 from EA, what it does is launching a new instance of Eclipse, it does not detect that Eclipse is already running. Because Eclipse was already running, then I got the warning message.
Now I am searching on Internet on how to change the way Eclipse runs to allow only a single instance of the application.
I will report back to here in case someone has a similar issue in the future.
