Author Topic: If I change an Interface... How to update classes?  (Read 5133 times)
Miguel Gonzalez
« on: December 02, 2010, 10:57:54 am »
I have a class that is implements an Interface. If I change the Interface's signature... Is there an automatic way of updating the class without having to remove the realization association and creating it again?
On a simple example of one Interface and one Class is easy but when talking of many, the thing gets complicated.
Re: If I change an Interface... How to update clas
« Reply #1 on: December 02, 2010, 09:34:24 pm »
Ctrl+O
philchudley
« Reply #2 on: December 03, 2010, 03:42:49 am »
Shouldn't that be Ctrl+Shift+O ?
Since Ctrl + O opens a project
Ctrl+Shift+O opens the Overiddes / Implements dialog, but it is my understanding that updates to interfaces have to be updated on each class separately using this technique
To "bubble" a change down to ALL classes, well first you have to get all the classes that implement an interface (Add Related Elements), then apply the changes. This is same old complaint, that you cannot apply changes to a selection of elements  :(
Unless there is a much quicker and more automated method
Cheers
Phil
Models are great!
Miguel Gonzalez
« Reply #3 on: December 03, 2010, 09:23:35 am »
I am with you Phil, not being able to apply changes to an entire selection of elements is far from ideal.
Also, Ctrl+Shift+O allows you to update new created methods in the interface but it does not allows you to make updates if you have deleted a method from the interface.
If you have changed the interface in a way that its signature offers less functionality, you have to delete those implemented methods manually from all classes that previously implemented.
Perhaps the "Overiddes / Implements" dialog should show you those methods that not longer exist on the interface and allow you to tick them to decide which one to leave and which one to remove from classes that previously implemented them.
« Reply #4 on: December 03, 2010, 03:25:04 pm »
Oops :-[ of course it is.
We had a discussion here recently about he very same subject a while ago. It might be useful to look that up and add to it.
Miguel Gonzalez
« Reply #5 on: December 05, 2010, 04:50:06 am »
I think it should be done. When using EA for software design, you need to do and re-do, and change many things many times. Having the "Overiddes / Implements" dialog showing you methods to implement or to not longer implement will be of great help.
sargasso
« Reply #6 on: December 06, 2010, 09:07:10 pm »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
