Author Topic: Code page, text encoding problem in EAP project  (Read 2878 times)
mtjakobczyk
« on: December 19, 2010, 11:06:23 pm »
I have created project in EA8 on windows xp with my national characters (Poland such as [ch261] [ch281] [ch322] [ch347] [ch380] [ch378] :D).
Now I migrated to OpenSuSE and installed EA on wine.
After loading .eap to EA on wine instead of my national characters I see wrong signs.
I suspect this would be solved after I change the code page for EA but I could not find a proper option.
Do you know where to find it?
Re: Code page, text encoding problem in EAP projec
« Reply #1 on: December 20, 2010, 08:34:05 am »
Are you using .eap files?  In that case you will need to find the option for WINE (or the bottle, I'm not a WINE expert that is equivalent to windows "Current language for non-Unicode programs".
Other options are:
Installing JET 4 (but I'm not sure if this is possible because JET 4 is only distributed with the OS and some other Microsoft products.) and upgrading your existing repository to use JET 4.
Using a "real" dbms, which also requires additional software installed into your bottle.
