Author Topic: diagram appearance configuration  (Read 3390 times)
ngong
« on: December 22, 2010, 02:52:46 am »
Dear long-established EA users
if the appearance of diagrams is configurable could you help me to find the place where information about configuration is available?
The problem at hand: When I drag an interface to a component it manifests as a port of that component. My diagrams get cluttered up from all the stereotypes that comes with the ports name if I name it just like the interface. However, the interface itself shall be bound to a stereotype. It simply shall not show up at ports but just the name of the interface.
Thank you for your kind help.  :)
Rolf
Re: diagram appearance configuration
« Reply #1 on: January 03, 2011, 07:14:31 pm »
Rolf,
If you can't find the correct setting in the options, then you could try to use the template package.
Put a diagram on there with the correct settings, and then create a new diagram and check if it has taken over the settings from the template diagram.
