Author Topic: Copy a base project on a DBMS?  (Read 3182 times)
John Brand
« on: January 07, 2011, 02:09:02 am »
Currently on 7.5.850 and using SQL Server 2008. To save going through the DBMS administrator to load a script for each new project I was hopüing there was a way of copying a base project and re-using?
Is this possible? Thanks.
Re: Copy a base project on a DBMS?
« Reply #1 on: January 07, 2011, 07:39:08 pm »
John,
The script needs to be used for each new database (to create the tables). After that is done you can do a project transfer from another model to copy it to the DBMS server.
You could ofcourse create a base model in a separate database, and restore a backup of that base model each time you need a new database.
Just curious, why is this a problem? Are you creating a new database for each project?
You do know that it is possible to host multiple models in the same database?
John Brand
« Reply #2 on: January 07, 2011, 07:43:10 pm »
Thanks, yes we have multiple databases on the DBMS. I'm looking for the easiest way to start a new project on the DBMS without having to bother the DBMS administrator.
« Reply #3 on: January 07, 2011, 07:46:56 pm »
I usually ask the dba to restore a backup of one of my other projects to a new database. Next to setting the security that is all the dba needs to do, the rest I can do myself.
But yes, you'll always need the help of the dba to setup a new database. (that's why its interesting to host multiple projects on the same database, then you don't need the help of the dba)
