Author Topic: Version Contol mishap  (Read 2748 times)
SomersetGraham
« on: January 28, 2011, 02:09:21 am »
Hi all
I have had an EA project under version control for some time now.
But today when I try to check out I get an error dialog informing me that the item is not under version control!
I can directly check out the item using the version control directly but this does not show up in EA
This is not a single item but all of the items in the repository
I would be grateful if anyone has any suggestions as to what may ahve happened
TIA
Graham
Using V12
Re: Version Contol mishap
« Reply #1 on: January 28, 2011, 05:27:42 pm »
Graham,
Could be that someone (by mistake) unchecked the "Control Package" checkbox.
Otherwise you could try to "Resynch status with VC provider"
SomersetGraham
« Reply #2 on: January 28, 2011, 07:22:44 pm »
Hi
Solved the problem!
For some reason one of the xml files was at the wrong location on the local filesystem and this seemes to stop vc in its tracks
Using V12
