Author Topic: Java Generics  (Read 6880 times)
Tim Pigden
Java Generics
« on: November 01, 2010, 07:10:53 am »
Hi, I'm struggling with a representation of Java generics.
How do I represent the following in a class diagram?
abstract class Calculator<ResultType, EntityType> {
  abstract ResultType calculate(EntityType entity);
class MyCalculator extends Calculator<Duration, MyEntity> {
  Duration calculate(MyEntity entity) {
Any suggestions?
Re: Java Generics
« Reply #1 on: November 03, 2010, 06:25:33 pm »
Tim,
Look for Parameterised Classes in the manual.
ukmtk
Re: Java Generics
« Reply #2 on: January 11, 2011, 12:44:29 am »
It seems that one can have template classes but not template interfaces? Java has template interfaces too (e.g. java.util.Collection) which was what I was attempting to model and discovered that I can't as the "details" tab does not display for interfaces?
Re: Java Generics
« Reply #3 on: January 11, 2011, 01:03:49 am »
What you could try as a workaround is to set the parameter on the a class, then change the type of the class to interface (Via Element|Advanced|Change Type)
When you need to change anything to the details you can change it back to class.
To make sure Sparx notes this inconsistency you better request a feature as well using the link on the bottom of the page.
Aaron B
Re: Java Generics
« Reply #4 on: January 11, 2011, 09:35:00 am »
Improved support for Generics / Templates (including Templated Interfaces) is currently scheduled for the next major version of Enterprise Architect.  No timeline available for this release as yet.
apetosa
Re: Java Generics
« Reply #5 on: February 08, 2011, 11:57:01 am »
Understood. In the interim I tried Geert's suggestion. Unfortunately, once the element's type is changed to <<Interface>>, the Java type parameter disappears; changing back to <<Class>> does not return the Java type parameter.
Is a "hack" possible using Code Template Syntax and/or Tagged Values? I don't care if it looks ugly; I'm simply interested in generating a genericized Java interface.
Thanks.
