Author Topic: [HELP] - Run-time association-class?  (Read 7661 times)
dr_shorthair
« on: February 15, 2011, 08:26:27 pm »
"An Association Class connector is a UML construct that enables an Associate connector to have attributes and operations (features). "
So in the object model that is a run-time instantiation of such a model, on the Associate connector between two objects classified appropriately either (a) it should support the assignment of attributes and operations or (b) it should allow an object classified by the association class to be connected.
I can't find a way to do this in the EA interface. Any suggestions?  :-?
Re: [HELP] - Run-time association-class?
« Reply #1 on: February 15, 2011, 08:51:09 pm »
If you add an instance of the AssociationClass to the diagram you can set the values for it's attributes using Right-click|Advanced|Set Run State.. , but I haven't found a way to actually show the isntance of the connector on the diagram.
I guess that is not supported (yet).
You can request a feature using the Feature Request link on the bottom of the page.
