Author Topic: Test Automation Features?  (Read 4029 times)
warenzevon
« on: November 10, 2008, 09:59:34 pm »
Does EA provide such facilities as automation testing, etc.?? If so, can someone provide a basic overview.
albinofrenchy
Re: Test Automation Features?
« Reply #1 on: November 18, 2008, 04:00:28 am »
I'm not sure exactly what you mean, but it sounds like you mean unit testing against the automation interfaces?
If so; then yes. You can instantiate the 'App' class and open a project and generally interact with EA's stuff programaticly. From there you can use your language appropriate unit testing suite to load and run tests.
warenzevon
« Reply #2 on: November 21, 2008, 07:31:20 pm »
Thank you for the reply. Well, that helps. I am not looking so much at Unit Testing, but I want to see if EA can generate test cases from "Use Cases". i.e, take the use cases, and provide the test case steps one by one, and look at the possibilities. For example, decision table techniques, etc.
bioform
  • Forty-Two?
« Reply #3 on: December 30, 2008, 05:32:12 am »
Have you had any luck pursuing this? Definitely something I also would be interested in.
Happy Holidays,
Time is what keeps everything from happening at once, Space is what keeps it all from happening to you. <unknown>
