Author Topic: RTF reporting use case scenarios?  (Read 2499 times)
marcopas
« on: March 25, 2011, 01:58:38 am »
Hi there i want to export the use case structured scenarios in EA8 but until now i get first the alternate flow and then the basic flow, i want this other way around. So first export the basic flow and below that the different alternate or exception flows. Any idea how i can achieve this?
AndyJ
  • It's only a model
Re: RTF reporting use case scenarios?
« Reply #1 on: March 30, 2011, 12:32:44 pm »
Hah ha!
I had this question in the past...
In the Scenarios tab of the Use Case, you are usually looking at the Structured Specification tab (half way down the pane).
Select the Description tab that is next to the Structured Specification tab.
Use the Up and Down finger icon to change the location of steps in the description tab. They will appear in this order when you generate the use case document in future...
Easy when you know how eh?
Andy
