Author Topic: How to change Source safe database  (Read 5714 times)
nestevao
« on: March 24, 2011, 01:50:20 am »
We are controlling versions trough MS Visual Source Safe. We had to change the SS database and we made a copy of the old one and created a new database. All files were checked-in and synchronized.
How can I change in EA Version Control (EA 8.0.864), the SS database to use.
Thanks in advanced,
Nuno
nestevao
Re: How to change Source safe database
« Reply #1 on: March 25, 2011, 09:56:13 pm »
Any suggestions?  :)
Thanks.
« Reply #2 on: March 28, 2011, 02:50:21 pm »
What have you tried?
Isn't it just a matter of setting the correct working folder?
nestevao
« Reply #3 on: March 31, 2011, 01:47:08 am »
I can't edit an existing control version configuration, so I can't change anything about it (except the local directory).
Last time we needed to change source-safe database, I had to create a new configuration and change all packages to the new configuration. We have a lot of packages  :-/
I would like to be able to edit the existing configuration and change the source database.
« Reply #4 on: April 05, 2011, 01:29:14 pm »
I think the version control configuration is stored in the registry somewhere.
Also on each controlled package there are some version control settings saved (t_package).
Changing either of those directly might be enough, and it might save you some time.
nestevao
« Reply #5 on: April 05, 2011, 09:36:07 pm »
Many thanks.
I've searched the registry before and found nothing about the version control settings but I've searched again and found a reference in a long, long, very long :) string value of a VCConfig key which includes the source-safe database reference.
Problem solved, thanks again.
