Author Topic: Import java not generating toMany relationships  (Read 3869 times)
klarson
« on: April 16, 2011, 07:32:26 am »
Importing java source code is not generating toMany relationships. For example having a class LodgingQuery with member
    protected List<LodgingType> lodgingTypes;
does not create a relatationship from LodgingQuery to LodgingType.
Is there something I need to set up for EA to recognize these generic containers?
I did spend quite a bit of time searching the forums as I'm sure this has been asked many times, but couldn't find anything.
thanks in advance.... great tool!
Aaron B
Re: Import java not generating toMany relationship
« Reply #1 on: April 18, 2011, 09:06:48 am »
Which version of EA are you running?  Try using the EA 9 beta if possible.  It has many improvements to the handling of generics/templates.
http://www.sparxsystems.com/products/betas.html
Markus W
« Reply #2 on: April 18, 2011, 06:46:33 pm »
I am using Enterprise Architect 9 Beta Prerelease (9.0.902).
In this version it doesn't work.
But the release notes contain the following:
Code Engineering: Reverse Engineering of Associations from Attributes with instantiated template type added.
Why doesn't it work in this version? In which version will it work?
« Reply #3 on: April 19, 2011, 08:30:32 am »
Go to Tools | Options | Source Code Engineering | Java.
Add 'List<#TYPE#>' to the 'Additional Collection Classes' option.
I'm not sure why it isn't in there by default, but will see that it gets added.
« Last Edit: April 19, 2011, 08:30:54 am by simonm »
klarson
« Reply #4 on: April 19, 2011, 11:21:20 am »
Thanks for helping... I don't see an ''Additional Collection Classes' option. I tried adding List<#TYPE#> everywhere else but no dice. There is a 'Default Collection Class' setting as well as a Collection Classes button with brings up a panel with three entries inside a 'static' box... These are labeled:
  • Default Collection Class
  • Collection Class for Ordered multiplicity
  • Collection Class for Qualified Multiplicity
As I said setting these has no impact to the imported JAVA code. Smells like these only affect code generation?
I'm using EA8
RoyC
  • Read The Help!
« Reply #5 on: April 19, 2011, 11:54:33 am »
[Edit: Thanks Aaron - yes, KLarson needs to try the latest EA 9.0 trial, as MarcusW is already doing.]
Select the Tools | Options menu option, then on the Options dialog select the Source Code Engineering | Java option.
This shows the Java Specifications page of the dialog. There are two sets of fields here, the top set being under the heading: Options for the current model. The last field in this set is Additional Collection Classes.
For Help, go to Software Engineering > Other Settings > Set Collection Classes and Software Engineering > Other Settings > Language Options > Java Options
« Last Edit: April 19, 2011, 01:30:59 pm by RoyC »
Best Regards, Roy
Aaron B
« Reply #6 on: April 19, 2011, 11:59:20 am »
I'm using EA8
The Additional Collection Classes field is only in Enterprise Architect 9.  You'll need to install the EA 9 beta to use these new options.
Markus W
« Reply #7 on: April 19, 2011, 06:36:13 pm »
Thanks, now it works.
But I have another question.
If I add a collection class , that has more than one template parameter , I can only set #TYPE# for only one template parameter.
e.g. Map<String,#TYPE#>.
Is it possible to define something like Map<#TYPE1#,#TYPE2#>?
