Author Topic: accessing an object's runsate from java  (Read 3256 times)
patfada
« on: January 16, 2009, 04:00:30 pm »
Hi
 I am trying to get the runstate from an object using the java automation API, but I haven't had any luck. I can find the attribute from
Element e.GetAttributesEx()
(Where element is the object)
but I can't get the runstate value
- anybody know how to do this?
cheers
Pat
Re: accessing an object's runsate from java
« Reply #1 on: January 17, 2009, 01:47:04 am »
There is an Element.RunState property that should return the list as a string. I think it is semicolon delimited.
FWIW, though this property is clearly documented, I seem to miss it when I look for it. This is a simple oversight on my part, but I've done it a couple of times when I forget the calling sequence (I don't use the run state much in automation). The most recent time was just now when I looked it up.
HTH, David
patfada
« Reply #2 on: January 18, 2009, 08:17:08 am »
- weird, I couldn't see it for looking...
