Author Topic: Howto find/show all hidden connectors?  (Read 4628 times)
Asperamanca
« on: April 28, 2011, 12:24:30 am »
In EA 8.0
I noticed that I must have hidden some connectors instead of deleting them, by mistake. How do I find and remove those unwanted connectors?
I have found no way to display the connectors in the project browser.
There's a "Relationship window" mentioned in help, but the corresponding menu entry does not exist.
In "Model search", I did not see an obvious way to search for hidden connectors (that is, connectors that do not have a single visible representation in any diagram).
What can I do?
Re: Howto find/show all hidden connectors?
« Reply #1 on: April 28, 2011, 02:30:53 am »
Try Ctrl Shift 2
EA changes the menu position from version to version...
« Reply #2 on: April 28, 2011, 04:44:21 pm »
If you know a little SQL you could write your own SQL search to return all hidden connectors.
You should look for connectors that have a diagramLink that is set to be hidden.
Asperamanca
« Reply #3 on: April 28, 2011, 05:05:14 pm »
Whoa, SQL sounds a bit overkill for such a simple search.
Ctrl-Shift-2 was exactly what I needed. Does anyone know where the menu entry is hidden in EA 8?
Aaron B
« Reply #4 on: April 29, 2011, 09:14:08 am »
In EA 8 (864):  View | Other Element Tools | Relationships
In EA 9 (902):  View | Relationships
The "Set Visible Relations" dialog might also be of use - it allows you to see if any relationships have been hidden on the current diagram and allows you to show them again.  With your diagram open, press [Ctrl]+[Shift]+.
In EA 8 (864):  Diagram | Visible Relations
In EA 9 (902):  Diagram | Advanced | Visible Relations
Asperamanca
« Reply #5 on: April 29, 2011, 04:54:10 pm »
No sir, I had to customize my menu in order to get it there. I had never opened the customize dialog before.
