Author Topic: 2+ repositories, in the same DB-Scheme  (Read 4005 times)
Luciano HG
« on: April 30, 2011, 12:17:12 am »
Hello all.
I have a DBMS MySQL repository. I have a DB installed, and a instance for repository.
If i need create a new DBMS repository project, do i need create a new instance (with respective tables)? Or i can store my new project in the same DB - instance that i have now?
Thanks in advance.
Luciano
Re: 2+ repositories, in the same DB-Scheme
« Reply #1 on: May 03, 2011, 04:56:00 pm »
Luciano,
You can have multiple projects in the same repository. Just add a new "root" node.
Luciano HG
« Reply #2 on: May 03, 2011, 11:07:53 pm »
Thanks, but my question is other:
I have a project stored in a DB.
Can i create a new .eap project, and then do the project data transfer (EAP
to DBMS) and select the same DB that i'm using now?
With this, i want to separate both project, but i want to reuse my DB instance.
Thanks anyway!
Luciano.
« Reply #3 on: May 04, 2011, 10:19:28 am »
to DBMS) and select the same DB that I'm using now?
Thanks anyway!
Luciano.
Hi Luciano
NO you can't do more than one project transfer to a target as the transfer will obliterate the target.  However, you can do an XMI Export from the 2nd .EAP Repository and then do an Import into the first Server based Repository.
XMI Import/Export is the normal way to transfer models (or parts thereof) between repositories.
Luciano HG
« Reply #4 on: May 04, 2011, 10:40:27 pm »
Thanks guys.
You were very usefull.
See you!
