Author Topic: Completely suppress EA UI when automating from C#?  (Read 3298 times)
eru
« on: January 20, 2009, 08:10:44 am »
I've created a service in C# that runs in the background and creates an updated HTML report every 30 minutes. How can I suppress the EA "Import Source Directory" window that appears every time Project.ImportDirectory() is called?
I've tried calling Project.ShowWindow(0), but the windows still appear.
Emory
eru
Re: Completely suppress EA UI when automating from
« Reply #1 on: January 21, 2009, 01:14:16 pm »
Ok, I've figured it out.
Now that I'm not in trial mode anymore, I made the C# Windows Service serviceProcessInstaller1 class use "LocalSystem" for the "Account" class member property.
After the Service is installed, under the Log On tab of the Service Properties dialog, I set the account to log on under an account that has domain network access. That way, I get the best of both worlds of having full local privileges while still being able to publish to a Windows UNC network share (e.g. \\network\share).
Set up in this way, the EA windows do not appear and everything runs smoothly in the background.
