Author Topic: Project Glossary  (Read 3238 times)
CheriS
Project Glossary
« on: May 14, 2011, 12:54:49 am »
We plan to deploy EA into a central repository. This repository will consist of multiple projects (root nodes).
Is there a way to develop/report (document) individual glossaries for each root node?
AlanT
Re: Project Glossary
« Reply #1 on: May 15, 2011, 10:15:17 am »
CheriS,
    A glossary is part of the project's documentation.  So, different projects have different glossaries as default.  (You can import and export them.)
                                   Alan
« Reply #2 on: May 15, 2011, 12:46:42 pm »
CheriS,
                                   Alan
But because EA conflates the idea of Repository and Project, you can only have one Glossary per repository although one can have multiple Project Roots per Repository.
« Reply #3 on: May 15, 2011, 07:38:40 pm »
It would be nice if some of the reference data (like the glossary) could be loaded dynamically from a (version controlled) xmi (like it's done with the MDG). In that way you could set up a global glossary across many projects. Having a project local repository in addition to overwrite global terms  would be an extra plus.
Because EA does not support this, we manage the glossaries externally.
