Author Topic: Import BPMN 2.0  (Read 3637 times)
mornindew
Import BPMN 2.0
« on: May 19, 2011, 03:25:00 am »
Hi all,
      I am curious if there is an easy way to import a BPMN 2.0 File.  I see how to create one (or at least the BPM Modeler).  How can I import an existing process?  Apologies for the simple question.
Thank you
Sunshine
  • Its the results that count
Re: Import BPMN 2.0
« Reply #1 on: May 19, 2011, 11:08:32 am »
Only V9.0 supports BPMNV2.0 so you'll need that version first of all.
You don't say what file format you want import it from so you may not get the answer you are looking for.
Yes you can import via XMI file generated by other tools.
There is a visio plug-in you can use too but you'll have to import it as an activity diagram and then change types and stereo types to match BPMN V2.0.
Happy to help
mornindew
Re: Import BPMN 2.0
« Reply #2 on: May 19, 2011, 11:38:39 am »
Thank you for the reply.  I am generating my bpmn file via Activiti.  I am not sure how to get it to a XMI file.  Below is a sample of the output that is generated from Activiti.  Thanks again for your help.
[code]<?xml version="1.0" encoding="UTF-8"?>
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
  <process id="helloworld" name="helloworld">
    <startEvent id="startevent1" name="Start">
      <extensionElements>
        <activiti:formProperty id="123" name="Test" required="true" readable="true" writable="true"></activiti:formProperty>
      </extensionElements>
    </startEvent>
    <endEvent id="endevent1" name="End"></endEvent>
    <userTask id="usertask1" name="User Task" activiti:assignee="kermit"></userTask>
    <exclusiveGateway id="exclusivegateway1" name="Exclusive Gateway"></exclusiveGateway>
    <userTask id="usertask2" name="User Task" activiti:assignee="kermit"></userTask>
    <userTask id="usertask3" name="User Task" activiti:assignee="kermit"></userTask>
    <exclusiveGateway id="exclusivegateway2" name="Exclusive Gateway"></exclusiveGateway>
    <userTask id="usertask4" name="User Task" activiti:assignee="kermit"></userTask>
    <sequenceFlow id="flow1" name="" sourceRef="startevent1" targetRef="usertask1"></sequenceFlow>
    <sequenceFlow id="flow2" name="" sourceRef="usertask1" targetRef="exclusivegateway1"></sequenceFlow>
    <sequenceFlow id="flow3" name="" sourceRef="exclusivegateway1" targetRef="usertask2"></sequenceFlow>
    <sequenceFlow id="flow4" name="" sourceRef="exclusivegateway1" targetRef="usertask3"></sequenceFlow>
    <sequenceFlow id="flow5" name="" sourceRef="usertask3" targetRef="exclusivegateway2"></sequenceFlow>
    <sequenceFlow id="flow6" name="" sourceRef="usertask2" targetRef="exclusivegateway2"></sequenceFlow>
    <sequenceFlow id="flow7" name="" sourceRef="exclusivegateway2" targetRef="usertask4"></sequenceFlow>
    <sequenceFlow id="flow8" name="" sourceRef="usertask4" targetRef="endevent1"></sequenceFlow>
  </process>
  <bpmndi:BPMNDiagram id="BPMNDiagram_helloworld">
    <bpmndi:BPMNPlane bpmnElement="helloworld" id="BPMNPlane_helloworld">
      <bpmndi:BPMNShape bpmnElement="startevent1" id="BPMNShape_startevent1">
        <omgdc:Bounds height="35" width="35" x="10" y="260"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="endevent1" id="BPMNShape_endevent1">
        <omgdc:Bounds height="35" width="35" x="1190" y="260"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="usertask1" id="BPMNShape_usertask1">
        <omgdc:Bounds height="55" width="105" x="210" y="250"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="exclusivegateway1" id="BPMNShape_exclusivegateway1">
        <omgdc:Bounds height="40" width="40" x="440" y="257"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="usertask2" id="BPMNShape_usertask2">
        <omgdc:Bounds height="55" width="105" x="570" y="40"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="usertask3" id="BPMNShape_usertask3">
        <omgdc:Bounds height="55" width="105" x="580" y="540"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="exclusivegateway2" id="BPMNShape_exclusivegateway2">
        <omgdc:Bounds height="40" width="40" x="830" y="257"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="usertask4" id="BPMNShape_usertask4">
        <omgdc:Bounds height="55" width="105" x="1000" y="250"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNEdge bpmnElement="flow1" id="BPMNEdge_flow1">
        <omgdi:waypoint x="45" y="277"></omgdi:waypoint>
        <omgdi:waypoint x="210" y="277"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
      <bpmndi:BPMNEdge bpmnElement="flow2" id="BPMNEdge_flow2">
        <omgdi:waypoint x="315" y="277"></omgdi:waypoint>
        <omgdi:waypoint x="440" y="277"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
      <bpmndi:BPMNEdge bpmnElement="flow3" id="BPMNEdge_flow3">
        <omgdi:waypoint x="460" y="257"></omgdi:waypoint>
        <omgdi:waypoint x="460" y="67"></omgdi:waypoint>
        <omgdi:waypoint x="570" y="67"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
      <bpmndi:BPMNEdge bpmnElement="flow4" id="BPMNEdge_flow4">
        <omgdi:waypoint x="460" y="297"></omgdi:waypoint>
        <omgdi:waypoint x="460" y="567"></omgdi:waypoint>
        <omgdi:waypoint x="580" y="567"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
      <bpmndi:BPMNEdge bpmnElement="flow5" id="BPMNEdge_flow5"
