Author Topic: Custom SQL in RTF reports  (Read 2523 times)
bch
« on: May 12, 2011, 07:48:46 am »
Is this possible?
Specifically I'd like to generate a typical RTF Requirements report with an additional few fields referring to a linked object's name.
For example, a single Actor Object is linked to each requirement using an Association relationship.  I would like to see the Actor's name as part of each requirement item in the report.
I've tried in vain to find an answer for this within the software documentation and the forum.
Thanks!
bch
Re: Custom SQL in RTF reports
« Reply #1 on: May 20, 2011, 04:19:11 am »
No one???
Did I explain the issue properly?
 I'd like a report much like the deafult requirements report, with additional fields showing what the requirement is linked to.
For example I have relationships from requirement to actor, and requirement to use case.  I'd like the report to show each requirement, with these relationships listed as below:
 00003: {requirement name}
«Functional»
      Status: Validated      Priority: Medium      Linked Actors:Customer Service,System A      Phase: 3.3      Version: 1.0      Linked Use Case: Pimary Use Case 1      {requirement notes are here}
