Author Topic: EA 9 documentation?  (Read 4794 times)
Asperamanca
EA 9 documentation?
« on: April 27, 2011, 06:17:08 pm »
Is there any preliminary EA 9 documentation available that I can read before installing?
Specifically major changes compared to EA 8, and whether I can install EA 8 and 9 side-by-side, or need to set up a virtual machine to try out EA 9.
Thanks!
Sunshine
  • Its the results that count
Re: EA 9 documentation?
« Reply #1 on: April 28, 2011, 06:08:38 am »
EA V9.0 is still in beta so you can install it in parallel with V8.0
Full release details and links to download files and resources can be found here:
http://www.sparxsystems.com/products/betas.html
If you want to look at the documentation then suggest installing the latest beta and looking through the on-line help.
Happy to help
« Reply #2 on: April 28, 2011, 04:47:39 pm »
I've setup the EA 9 side-by-side to my EA 8, and unfortunately I experienced an issue with my tooling when trying to connect to the running instance of EA.
I had to re-install version 8 to fix it.
I think v9 uses a different name (not "EA.App" in the "running object table" or something like that, need to investigate further)
Asperamanca
« Reply #3 on: April 28, 2011, 05:01:17 pm »
Thanks to both! I've decided to install it on a virtual machine, just to make sure, and it seems to work just fine.
« Reply #4 on: April 29, 2011, 09:02:57 am »
Geert, if you're having trouble with that my suspicion is that for some reason EA is not registering itself properly and I would appreciate it if you let support know any details that you have to reproduce it.
« Reply #5 on: April 29, 2011, 05:21:44 pm »
Simon,
I'll try to find some time to test it again and send you the details.
« Reply #6 on: May 23, 2011, 05:09:38 pm »
Simon,
The problem disappeared on my work computer (XP 32bit) after uninstalling/reinstalling EA.
But now I have the same problem on my home computer (Win7 64bit), and no amount of uninstalling/reinstalling seems to fix it.
I checked the RunningObjectTable, but I can't find a difference there. Both mention !Sparx.EA.App:<someNumber>
I'll compare the registry keys between the two installations and let you know what I find.
