Author Topic: Retro engineering : class/SQL schema  (Read 4307 times)
Guillaume
    • www.umlchannel.com
« on: May 11, 2011, 05:40:20 pm »
Hi
My client sent me the DB schema i.e. all CREATE TABLE SQL scripts
I'd like to generate a DB diagram in EA from these scripts, and then generate a class diagram .
Any hint on how to do this?
thanks
Guillaume
Re: Retro engineering : class/SQL schema
« Reply #1 on: May 11, 2011, 06:51:07 pm »
- Create the database using your script
- Import the database structure via ODBC into EA
Guillaume
« Reply #2 on: May 13, 2011, 02:31:03 am »
thanks for the info Geert
Guillaume
Guillaume
« Reply #3 on: May 23, 2011, 07:53:13 pm »
Strangely enough since EA can generate SQL scripts to create the dB tables from your db schema model, you would think that it can read SQL CREATE scripts to generate a model instead of having to create the schema in a DBMS and import via ODBC.
Unless EA9 supports this..
Guillaume
« Reply #4 on: May 23, 2011, 08:50:10 pm »
Nope nothing like that in v9.
« Reply #5 on: May 24, 2011, 12:40:27 pm »
It is a feature I'd like, and I think should be there.
Vote.
Please submit it as a feature request.
Guillaume
« Reply #6 on: May 24, 2011, 04:18:47 pm »
already done yesterday  ;)
Guillaume
