Author Topic: Default Scope and Type for Attributes on Class Dia  (Read 4791 times)
AndyJ
  • It's only a model
« on: May 31, 2011, 09:25:06 am »
Hi people,
I've had a rummage around the fora and only found other people wanting this function...
Is there any way to set the defaults for attributes of classes?
Currently the default is Scope:Private and Type:int
I would prefer the Scope to be Public and Type to be none...
I've tried creating a template package, but the nearest thing I've been able to achieve is a default class containing a default attribute appearing on each new class diagram.
Andy
« Last Edit: May 31, 2011, 09:29:58 am by novaphile »
Re: Default Scope and Type for Attributes on Class
« Reply #1 on: May 31, 2011, 03:21:27 pm »
Andy,
I don't think you can configure this out of the box.
You could probably write an addin that does that for you though
