Author Topic: EA 7.0 - Beta 3 Released For Registered Users  (Read 26091 times)
sparks
« on: June 25, 2007, 09:38:08 pm »
Sparx Systems is proud to advise that Enterprise Architect 7.0 BETA 3 is now available for download.
Registered users can access EA 7.0 BETA 3 from the Registered User section of our website at http://www.sparxsystems.com/registered/ea_beta70.html
Please note that EA 7.0 BETA is provided for evaluation and informational purposes as BETA software, and should not be used with production models or on production machines.
Please report any bugs by using the Registered Users Beta Bug Report page. Direct any suggestions or comments to [email protected]
Fixes and changes since EA 7.0 BETA 2 Build 811:
Added a Mind Mapping profile to default installation, including a new Mind Mapping diagram type.
Improved the adjustment of objects when messages are moved on sequence diagrams.
Improved support for importing Operation Pre/Post-Conditions from Rose exported XMI 1.1
Improved import of attributes and operations on Activity from XMI 1.1
Updated saving database views after modification.
Improved import of reference data on Oracle repositories.
Allowed import of MySQL tables with space(s) in their name.
Changes to Audit Settings and Audit Operations (Clear, Save, Load) are now recorded.
Improved performance of Audit View/Project Browser integration.
Made Discussion Forum editable in the read-only (Lite) version. Enables user feedback to be input by Lite users.
Introduced context-menu UML help for all element, diagram and connector types.
Dynamic updating of sequence numbering when option changes.
Prevented datatype changes where a table is in a locked package.
Modified Select By Type menu item to restrict available choices to those on a diagram and allow selection by stereotype
Added support for round-tripping "nillable" on XML Schemas
Added handling of moved associations and updated role access to reverse engineering.
Added the automatic update of diagrams when deleting a connector constraint.
Added additional macros for accessing package properties in code/transform templates.
Added an option for default diagram in html report.
Additional bug fixes and performance improvements.
Some graphical updates to icons
Updates to Help file
« Last Edit: June 25, 2007, 09:40:14 pm by sparks »
