Author Topic: Use Function macro in addin  (Read 4035 times)
TheTwo
« on: January 28, 2009, 10:06:34 pm »
I'm trying to realize an Add-In (C#) that writes an special xml-file. In this file also a javadoc should be inserted.
Is it possible to use the fuction macro JAVADOC_COMMENT to receive e.g. a string with the javadoc of a class in my Add-In?
Thanks for reply
TheTwo
Re: Use Function macro in addin
« Reply #1 on: January 29, 2009, 08:12:44 am »
No, unfortunately you can't, so you'll have to manually do it using the API values instead.
Fortunately it is very simple.
