Author Topic: Extracting interface messages and generating API  (Read 2729 times)
Mark Jones
« on: June 30, 2011, 12:21:36 am »
Is there an automated way of generating an API from sequence or activity diagrams.
I have a number of use cases with associated activity & sequence diagrams where for example the activity(or Sequence) diagram shows messages exchanged between two module (e.g. UI and Application layer)
What I would like to do is to generate a report/list (rtf) of the messages hence creating an API document of the interface between UI and Application layer.
Dave_Bullet
Re: Extracting interface messages and generating A
« Reply #1 on: June 30, 2011, 02:20:06 pm »
I don't know of an automated way.
RTF generation works at a package level and you can specify per diagram whether RTF will document all elements contained on a diagram.  you could try fiddling with that
Otherwise, are you comfortable with SQL?  I have done exactly what you are after for communication diagrams - grabbing the collaborations in order and spitting them out in a spreadsheet (along with message, conditions, constraints, source and target elements etc).
« Last Edit: June 30, 2011, 02:21:55 pm by Dave_Bullet »
Mark Jones
« Reply #2 on: July 01, 2011, 08:48:35 pm »
Hi Dave,
The SQL route would seem the best way for me to achieve what i want. I just need to get and "idiots guide to sql" before  I delve into the model database.
thanks
 ;D
