Author Topic: EA 8 - doc generator + dynamic templates  (Read 2868 times)
Martinigue
  • BlackBerry is a lifestyle
« on: June 29, 2011, 11:52:37 pm »
Hi everybody,
assume a EA project, where the master model contains, say, five packages. Now, I'd like to run F8 on the master node with a template set up, however, I'd like for each package to use a different sub-template ( e.g. so that a business requirements package and a use case model package will produce differing - data-wise as well as visually - outputs). Is something like that possible in the first place?
Sunshine
  • Its the results that count
Re: EA 8 - doc generator + dynamic templates
« Reply #1 on: June 30, 2011, 08:44:01 am »
To use different templates for different packages try looking at master and virtual docs.
http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/report_generation/create_master_document.html
Happy to help
Martinigue
« Reply #2 on: July 07, 2011, 06:34:50 pm »
For some reason this gives strange results the first try, but it looks like the way to go, I'll have to figure that out. Thank you for the hint!
