Author Topic: Can the automation interface create an EAP fIle?  (Read 3205 times)
Steve Wartik
  • Why aren't I outside?
« on: February 05, 2009, 03:25:56 am »
Is there a method in the automation interface that can be used to create a new EAP file? In other words, I'd like functionality equivalent to the "Create a New Project..." link on EA's start page. I haven't found a method in a place that seems obvious (to me).
I'm using the Java API if that makes a difference.
Thanks in advance for any and all help.
Re: Can the automation interface create an EAP fIl
« Reply #1 on: February 05, 2009, 07:43:31 am »
I don't think so.
What we've always done is something along the lines of the way EA does it internally. Copy a predefined 'seed' file - EA defaults to EABase.EAP in the installation directory, but you can use others - to the desired destination, then rename it as appropriate. Then just open the file with the EA Repository object.
You would go through an analogous process to create a new DBMS repository, creating a new schema with an appropriate name. In this case there is an additional step that cannot be omitted. You must initialize the schema with the necessary data to start a meaningful project. When working by hand you do this via the Project Transfer function in EA. There is no API equivalent - yes, we've asked - so you need to handle this another way.
One method is to create an empty 'reference' repository and do a project transfer by hand. Then extract the data via whatever ETL tool works for you. When you create a new schema run a job to load the data. Depending on the DBMS you might also be allowed to copy your reference schema and just use the copy as your starting point.
