Author Topic: EA 9.0 and 7.5 coexist?  (Read 8175 times)
EricP
« on: June 16, 2011, 07:31:18 pm »
Can EA 9.0 and 7.5 coexist on the same machine, to be called up as needed?
Are there differences in the database format (.eap) so that once a project is used with 9.0 it can no longer be used with 7.5?
Re: EA 9.0 and 7.5 coexist?
« Reply #1 on: June 16, 2011, 09:40:37 pm »
I'm working with both and have encountered no problems. Simply rename the EA folder to EA7.5 and install EA9. You can start the EA7.5 exe manually via dbl-click.
EricP
« Reply #2 on: June 16, 2011, 09:51:04 pm »
So, you have run into no incompatibilities in the database format between 7.5 and 9?
« Reply #3 on: June 16, 2011, 10:41:30 pm »
No, no issues so far, and I'm running 9.0 for a few months now where the rest of the team is still on 7.5.
EricP
« Reply #4 on: June 16, 2011, 10:44:02 pm »
OK, thanks, Geert.  And I thought I was the only one still running 7.5! :-)
« Reply #5 on: June 17, 2011, 12:46:25 am »
We wanted to upgrade to 8.0 almost a year ago, but we found the bug with the disappearing spaces a show stopper.
That bug didn't get fixed before 9.0
EricP
« Reply #6 on: June 21, 2011, 07:47:05 pm »
Good morning, q.
Well, it appears it won't allow me to do that.  It tells me I have to uninstall version 7.5 first and asks if I want to do that automatically, and when I say "no", it will not continue the install process.
« Reply #7 on: June 21, 2011, 08:08:14 pm »
Just say yes.
I've you've renamed the folder it won't delete any of the program files.
Dave_Bullet
« Reply #8 on: June 24, 2011, 01:38:43 pm »
Rename the existing folder - eg. EA_75
This fools it and all is well to run the EA9 installer.
PS: I'm running 8.0 and 9.0 concurrently on the same model on the same machine.  this is because sync stererotypes is broken on 9.0
abruckner
« Reply #9 on: July 11, 2011, 06:05:10 pm »
@Geert: the EA-COM components get overwritten when installing EA 9. Did you experience any strange behavior?
Guess, it's still more safe to install the "second" EA into a virtual machine.
« Reply #10 on: July 11, 2011, 06:08:33 pm »
Yes, I did experience some strange stuff now and then (like EA crashing when I tried to "attach to running process" in VS), but that got solved by uninstalling/reinstalling EA
