Author Topic: Empty space under image in RTF  (Read 2375 times)
Ninca
« on: July 19, 2011, 11:09:47 pm »
I want to structure my generated rtf document like this:
 - overview diagram containing uml elements
    - element in diagram, e.g. use case: heading + text description + image
This images are in an image format (.png, .jpg, .gif).
I did realize this RTF structure by creating a (interaction overview) diagram under the element which only contains one image.
When I create a RTF-Document the image gets automatically drawn right under the text. Below the image I  configured a caption in the rtf template.
And here my problem:
Sometimes in the generated diagram-image there is a white space (about approximately 2 cm) below the original image contained. It seems to me that if I change any settings of that diagram (Properties-Tab Diagram) then no white space is drawn below the original image - but only until I close the program and restart it. Then its there again though I did Save all. That's really nerving.
Is there anything I might do against it?
