Author Topic: Re: Is there a way to flush stereotypeEx property  (Read 2659 times)
« on: July 22, 2011, 07:18:16 pm »
Vinay,
I don't think I had an issue with resetting the stereotype's on an element, but... there's always a backdoor.
If the API doesn't expose a certain feature, or it won't update it, you can use Repository.Execute to execute your own SQL update string to the database.
That backdoor allows you to do virtually anything, even if its not possible using the "regular" API methods.
Here's the code I use to manipulate the stereotypes on an element (don't forget to call update() as well)
       /// <summary>
        /// returns a list of all stereotypes
        /// </summary>
        /// <returns>a list of stereotypes</returns>
        public override List<string> stereotypes
            get
                List<string> stereotypeList = new List<string>();
                string stereotypes = wrappedElement.StereotypeEx;
                if (stereotypes != string.Empty)
                    stereotypeList.AddRange(stereotypes.Split(new char[] { ',' }));
                return stereotypeList;
            set
                this.wrappedElement.StereotypeEx = string.Join(",", value.ToArray());
« Reply #1 on: July 23, 2011, 02:22:19 pm »
t_xref?
