Author Topic: class diagram box resize  (Read 5079 times)
itzdavide
« on: July 30, 2010, 10:45:41 pm »
Is there a way to resize the class diagram boxes and have the operations wrap to the next line when it cannot fit within the box?
I have a constructor with a long parameter list and the EA extends the box to fit the constructor.  This creates a lot of dead space and creates a wide box that requires you to zoom out to see everything.  By zooming out, the fonts scales down and the other classes in the diagram becomes unreadable.
Re: class diagram box resize
« Reply #1 on: August 02, 2010, 08:49:08 am »
Element | Feature Visibility.  There's an option there to wrap features.
itzdavide
« Reply #2 on: August 02, 2010, 09:16:21 pm »
Thanks!  Exactly what I was looking for.
Is there a way to set this globally for all elements?
« Reply #3 on: August 02, 2010, 09:57:51 pm »
I don't really see the option in Tools/Options, but what you could try is to setup an element like that in the "template package".
That might results in all new (diagram?)elements having that option.
AndyJ
  • It's only a model
« Reply #4 on: July 28, 2011, 03:12:53 pm »
Bump.
I'm trying to use this feature to stop long flat classes from being created, when an attribute is quite long - eg. where the attribute name is long, and there is an enumeration and a default value...
Unfortunately, for some classes...
while I'm able to select Feature Visibility, Wrap Features, the class is bumping back out to the size of the longest attribute...
Other classes, this seems to work as intended...
Is this worthy of a bug report or am I doing this wrong?
9.09.906
Andy
« Last Edit: July 28, 2011, 03:15:26 pm by novaphile »
« Reply #5 on: August 03, 2011, 09:42:12 am »
Sounds like a feature request that I would support
AndyJ
  • It's only a model
« Reply #6 on: August 03, 2011, 09:53:14 am »
The feature is working...
...just not all the time.
I haven't been able to work out what causes it to fail occasionally...
My current best guess is that it was a conflict between two of us trying to modify the same class.
If I can work out what causes it to happen, I'll put in a bug report.
