Author Topic: Looking up a Resource's in an RTF Report  (Read 3197 times)
NeilKC
« on: August 18, 2011, 10:41:14 pm »
I want to modify the Resource Allocation RTF report to include each resource's organisation.  But unfortunatley Organisation is not available as a field when processing each resource.  Is it possible to look it up as the report is generated?
If you don't know where to see the Organisation for a Resource you can see it from Settings->Project Types->People... then on the Resources tab.
Neil
Luis J. Lobo
  • IT Consultant
Re: Looking up a Resource's in an RTF Report
« Reply #1 on: August 18, 2011, 11:20:11 pm »
The "Resource" section into the Package or Element sections hasn't the Organization field.
The only way to show the resource's organigazion is to create a table with the list of the Resources and its Organizations as the first chapter of the document (into the "Model | Resources" section of the RTF template) and then proceed with each element documenting its resources without the organization field.
kr,
NeilKC
« Reply #2 on: August 18, 2011, 11:23:38 pm »
Thanks Luis.  I feared that that might be the answer  :(
Luis J. Lobo
  • IT Consultant
« Reply #3 on: August 18, 2011, 11:32:12 pm »
Another option:
You can put the Organization name as a part of the Resource name in the People window.
For example:
Joseph Murray (Sparx Systems)
Then, the Resource name always shows its organization...
« Last Edit: August 18, 2011, 11:33:09 pm by Deiser »
