Author Topic: SQL Search failing on Model Document  (Read 3219 times)
philchudley
« on: July 28, 2011, 12:46:26 am »
Hi All
Having read the user guide, it is very specific as to what MUST be included in a custom SQL search for use with a Model Document element (search specified by a tagged value)
Here is my search
from  T_Object a, T_Object b, T_ObjectProperties
where b.Name = '<Search Term>'
and a.Object_ID = T_ObjectProperties.Object_ID
and T_ObjectProperties.Property = 'DBApplicationModuleRef'
and b.ea_guid = T_ObjectProperties.Value
When run from the search view, all is well and I can select the items listed in the result, right-click and generate my documentation using a rather simple RTF template
BUT, when set as a tagged value in a model document, a suitable value entered in the search term tagged value, it fails every time with a rather unhelpful message
"Documentation Generation Failed"
I have checked the usual suspects
I have not got any packages in my Model Document element
The search most definately returns a list of elements
Any ideas?
I did also try a very simple sql search (the one in the user guide), that also failed in the same way!
I using the latest build of Version 9.0, but it also fails in Version 8.0
Cheers
Phil
Models are great!
philchudley
Re: SQL Search failing on Model Document
« Reply #1 on: July 28, 2011, 12:58:30 am »
Sorry all,
My SQL search on the initial post was not the right one!
Here is the complete search that is failing
select activity.ea_guid as CLASSGUID, Object_Type as CLASSTYPE
from T_Object activity left join T_ObjectProperties taggedValues on activity.Object_ID = taggedValues.Object_ID
where taggedValues.Property = 'DBApplicationRef'
and taggedValues.Value = (select ea_guid
                                         from T_Object where name = '<Search Term>')
Models are great!
snoack
  • UML Dino
« Reply #2 on: August 22, 2011, 10:29:18 pm »
Same situation here.
All model documents with SQL queries that used to work perfectly with v7.5 now fail with v8.0.
This is a major bug because sql queries are the only way to evaluate specific information that cannot be seleted otherwise.
As a result we now have to change the templates and spend hour deleting unwanted stuff from our documents.
 >:(  >:(  >:( - S. Noack
