Author Topic: help  (Read 3454 times)
bm
help
« on: August 21, 2011, 10:09:53 pm »
hi! im start to use new E.A. i have some questions. first, how [ch305] can show my java/c++ code in to the squantial diagram? i want to see uml diagram while the code running. i mean how can i see my code's sequence diagram.  how i can do that? thans for helps.
« Last Edit: August 22, 2011, 09:00:13 am by bm »
sargasso
Re: help
« Reply #1 on: August 22, 2011, 08:49:31 pm »
 :-X no wuckin furries bm, glad to help.  i have always wanted to see my code ruining a squantial diaphram too! :-X
But, to be serious, please try and take some little steps first.  There appears to be a learning curve ahead of you and it's very steep.  There is a lot of help available in the sparks website.  I am sure you have read the relevant ones, but just to be sure, well have you?
On a final note, may the pope forgive me, I get the feeling you are trying to approach a solution to the wrong problem.  Just what benefit do you feel you will derive from showing your executable code in a UML diagram?
p.s. It's always a joy to come back here and find that the future is in safe hands.
« Last Edit: August 22, 2011, 08:54:45 pm by sargasso »
bm
Re: help
« Reply #2 on: August 23, 2011, 03:31:27 am »
Actually i m try to see, how functions interact with each other? with static analyis, i can show only which class call other class or something as, but with dynamic analysis i can see, relation of func like which one call other funcition. How i can do that? with or without enterprise arct?
RoyC
  • Read The Help!
Re: help
« Reply #3 on: August 23, 2011, 09:32:01 am »
The information you need is provided in the Help, in the section titled Visual Execution Analysis. However, in setting up VEA you must create Build and Debug Analyzer Scripts, which are described in the Software Engineering > Code Build & Debug section.
Have a look through those sections, and if you have any problems post some more questions here.
Also, if you would like some help in understanding the English text, or in asking questions about it, you can post requests and questions in your own language. It's very likely other users can help translate, or provide information in your language.
Best Regards, Roy
