Author Topic: Modelling foreign key targetting an unique  (Read 2193 times)
Bohusz
« on: August 24, 2011, 05:28:23 pm »
I want to connect two tables with a foreign key relationship with an unique constraint on the master side instead of primary key.
CREATE TABLE adm_permission (
  serno  SERIAL PRIMARY KEY,
  permissiontype INTEGER,
  UNIQUE (serno, permissiontype)
CREATE TABLE adm_publicpermissions_bnd (
  refperm INTEGER NOT NULL,
  permissiontype INTEGER NOT NULL,
  FOREIGN KEY (refperm, permissiontype)
      REFERENCES adm_permission(serno, permissiontype),
  CHECK (permissiontype IN (1,2,3,4))
(SERIAL is an Informix way to declare autoincrementing INTEGER column).
As you can see, the opposite side of the FK is not, strictly speaking, a candidate key, it's just a superkey.
Enterprise Architect (9.0.907) resists to model it. I can't figure, if I do it wrong way, or the EA can't do it at all, or whether it is just a bug.
Here is the procedure I use:
1. I connect the tables dragging the Quick Link icon from detail (adm_publicpermissions_bnd) to master (adm_permission):
2.  Then I chose, that I want to create a general association:
3.  Then I right-click the newly created association:
4.  ... and choos the Foreign Keys... item from the menu:
5. Finally I chose key columns on both sides of the relationship and hit the OK button:
EA responds, that "All primary key columns must be selected!", which is totally non-sense, because:
  1. I don't want to use the PRIMARY KEY.
  2. I've chosen all columns of the superkey I want to use.
  3. In fact all columns of the PRIMARY KEY - i.e. the column serno have actually be selected. (But it's just a word-play.)
« Last Edit: August 24, 2011, 06:10:44 pm by Bohusz »
-- Bohusz
