Author Topic: Backtracking Information Items  (Read 4987 times)
Jalakas
« on: August 26, 2011, 06:50:28 am »
Adding information items to an information flow gives me a tool for coupling flows and information items. But what I know I can only view this relationship by picking a certain connector and select "Information Items Conveyed".
I would like to do it the other way around. Be able to list what Information Flows are related to a certain Information Item. That is, starting from the Information Item and list "Information Flows Conveyed". Anyone who knows if this is possible?
OpenIT Solutions
Re: Backtracking Information Items
« Reply #1 on: August 26, 2011, 09:01:09 pm »
The SQL below might help:
select * from t_connector, t_xref, t_object where t_xref.Client = t_connector.ea_guid and t_xref.description = t_object.ea_guid
Run this in a search (or add to a search that you can then us when generating rtf docs) and click on an output row and the information item properties will be shown in ea.
Jon.
denty
« Reply #2 on: September 05, 2011, 08:26:18 pm »
How could I use the results of the query to find out what diagrams the flow is shown in?
Jalakas
« Reply #4 on: September 06, 2011, 12:11:44 am »
Interesting features I haven't previously explored. Originally though my intent was to find simple way to do it via the GUI.
/Robert
OpenIT Solutions
« Reply #5 on: September 06, 2011, 02:34:51 am »
Great artical Geert.
@denty, try something like this (works on access, issue with type conversion on sql server) :
select  t_diagram.Diagram_ID AS CLASSGUID, t_diagram.Diagram_Type AS CLASSTYPE, t_diagram.Name, t_connector.Connector_Type, t_object.Name
from t_connector, t_xref, t_object, t_diagramobjects o1, t_diagramobjects o2, t_diagram
and (t_connector.Start_Object_ID = o1.object_id and t_connector.End_Object_ID = o2.object_id)
and t_diagram.Diagram_ID = o1.diagram_id
You can create a new "search builder" query with this, then use find in project browser on the search results to navigate to the diagram...
Jon.
