Author Topic: locked diagram?  (Read 4771 times)
dschmid2
locked diagram?
« on: September 02, 2011, 06:46:32 pm »
Hi there
I observed a strange behaviour in EA class diagrams. After modifying a diagram (adding class, modifying relation etc), the diagram is locked in a way, that i cannot move elements anymore. I can still add relations, add members to classes, but I cannot MOVE anything on the diagram.
After waiting some minutes, the diagram is unlocked in some magical way, and without any further notice, I can do everything again...
Did anybody observe this behaviour aswell?
I installed the latest version 909 and it still appears...
Using EA 9.1.909 on Win7, C++ Code Generation
Re: locked diagram?
« Reply #1 on: September 05, 2011, 06:52:57 pm »
No sorry, never seen such behavior.
Re: locked diagram?
« Reply #2 on: September 06, 2011, 01:12:32 am »
What kind of database are you using?
dschmid2
Re: locked diagram?
« Reply #3 on: September 06, 2011, 03:46:48 pm »
I'm using an EAP standalone file.
This is the way to reproduce the bug:
1. Press F12 on a class to show the C++ code hpp and cpp
2. Close the code editors
3. Try to move around the class -> it is locked !!!
4. After some time, it is unlocked again  :-?
5. Repeat from step 1
Re: locked diagram?
« Reply #4 on: September 06, 2011, 08:09:17 pm »
Unfortunately I can't repro since my F12 is used for other things (running a VM). Maybe someone else can confirm, but if it is reproducible like that you should report it as a bug.
Re: locked diagram?
« Reply #5 on: September 07, 2011, 08:46:33 am »
I can't reproduce it using those steps.
Can you reproduce it if you import the classes into a brand-new eap file?
