Author Topic: Model Validation bug?  (Read 2249 times)
Guillaume
    • www.umlchannel.com
« on: October 13, 2011, 05:50:21 pm »
Hi
I tried EA model validation feature and found a bug (even on v9.1) : in the help, it shows as an example  that if you link a class to an activity, it should yield an error within the results of the Model Validation.
However despite enabling all validation rules, and association a class to an activity and a class to an object, no error is returned by EA.
Only an inheritance on the same class yields an error.
Any clue?
Another point : can it be compared with Doors Analyst check feature?
Guillaume
RoyC
  • Read The Help!
Re: Model Validation bug?
« Reply #1 on: October 17, 2011, 12:03:17 pm »
Well, the Help does not say that if you link a Class to an Activity it should generate an error. An Association between a Class and an Activity is valid UML.
The Help should say that you cannot have a Generalization with a Class (general) as the source and an Activity (specific) as the target. It ought to be the other way around (if you really wanted to link a Class and Activity in this way anyhow).
Model Validation ought to pick that up. It does not. It ought to pick up, too, that an Association between a Class and an Object is not valid UML. It does not. I have sent a bug report through for those two points.
Best Regards, Roy
