Author Topic: Generate XML Scheme from package  (Read 4640 times)
FrankB
« on: October 20, 2011, 01:55:55 am »
did anybody generated a (XML) schema from a package? I'm trying to do that, but I get following msg: "One or more Packages missing Filename" And of course no information in the help what to do ... The checkbox "promt when missing filename" doesn't seem to do anything ...
Thanks in advance
Frank
VK
Re: Generate XML Scheme from package
« Reply #1 on: October 20, 2011, 03:32:21 pm »
You need to specify the file path before generating the XML Schema.
Set the file path using the Select XML File dialog that pops up when an entry in the list-box in the Child Package Options group-box is double-clicked.
FrankB
« Reply #2 on: October 20, 2011, 06:00:10 pm »
Thanks a lot  -it worked. I hope not all functions are so well hidden – otherwise I know the result of the evaluation already now …
Frank
